Can it be caused by a dying fuel pump? The reason I asked that is because I can hear a hissing sound coming from the fuel tank which lead me thinking that the fuel pump is on its way out.
dantheman wrote:Spark plug gaps might be incorrect.
razmrtwo wrote:dantheman wrote:Spark plug gaps might be incorrect.
If so, what is the correct spark plugs gap for a stock 3SGTE?
razmrtwo wrote:What is the correct spark plugs if I am to buy Bosch Platinum plugs?
razmrtwo wrote:Peter Gidden, do you know which of the Bosch platinum model should I buy?
Peter Gidden - SBITS wrote:razmrtwo wrote:Peter Gidden, do you know which of the Bosch platinum model should I buy?
If you want Bosch, FR7DPX.
