The reason I don't want the sensor in the sump is I'd like a vaguely comparable reading after fitting the oil cooler.
Where else could I fit an oil temperature sensor on a rev3 3s-gte that is post filter so I can compare old and new figures?
lmt wrote:any confirmation if it's 1/4 BSP?
GreddyMR2 wrote:Not creating a new topic, I will ask here.
What is the best place to put oil temp sensor in rev1 turbo? I was planning to fit it in sandwitch plate, but I've read that it's not a good location because of exhaust manifold.
Thank you for advices!
Peter Gidden - SBITS wrote:GreddyMR2 wrote:Not creating a new topic, I will ask here.
Weld an adaptor in the sump.
shinny wrote:What's wrong with a sump plug adaptor for the temperature?
