[Mk2] [Turbo] Fuel computers - worth it?
garry goodall
Post by garry goodall »
anyone using a fuel computer, apexi neo or simular to reduce the AFR's on their turbo's ?
I know the standard ECU runs very rich on my rev 3, a recent dyno shown low 10s on a run.
the question is what kind of power can be had from trimming the fuel map down to a leaner mixture? is it worth it?
I think i ran 11.5 AFR on my starlet turbo with a piggy back ecu which was deemed safe?
current mods are: Induction kit, Decat, MCB 1.1 bar, uprated intercooler, blueflame exhaust
Mr2 Rev3 Turbo
djpkins
Re: [Mk2] [Turbo] Fuel computers - worth it?
Post by djpkins »
no...it's an old way of doing things and not too safe..better to get a mappable ecu,
http://www.lovehorsepower.com/MR2_Docs/Tuning.htm
worth a read.
Draven
Post by Draven »
Get yourself a mappable ECU and get a decent map on it.. :thumleft:
Nic
Post by Nic »
Don't bother.
I'd check if the oxygen sensor is working properly if the car is running rich.
Marf
Post by Marf »
Nic wrote:Don't bother.
The oxygen sensor has nothing to do with on boost fuelling, it only works on at idle, very low load and cruise situations.
Nic
Post by Nic »
Marf wrote:The oxygen sensor has nothing to do with on boost fuelling, it only works on at idle, very low load and cruise situations.
Yeah, that'll teach me to not to read the thread properly :D
garry goodall
OK, staying away from them :thumleft:
Mr2 Rev3 Turbo
garry goodall
djpkins wrote:no...it's an old way of doing things and not too safe..better to get a mappable ecu,
worth a read.
not very consistant are they, will look at an mappable ecu
Mr2 Rev3 Turbo
toyokid
Fuelling
Post by toyokid »
Another option could be to buy an adjustable fuel pressure regulator?
You need to set it up on a rolling road or run a wideband sensor?
This would give you the option of reducing fuel pressure which has been shown to benefit power and consumption.
Stephen
Marf
Re: Fuelling
Post by Marf »
toyokid wrote:Another option could be to buy an adjustable fuel pressure regulator?
Stephen
REALLY bad idea.
djpkins
Post by djpkins »
doesn't the oem fpr increase the pressure psi/psi when it detects a rise in the boost pressure....or something trick like that.
toyokid
Re: Fuelling
Post by toyokid »
Stephen
REALLY bad idea.
Why?
Marf
Re: Fuelling
Post by Marf »
Stephen
REALLY bad idea.
Why?
Because altering the fuel pressure affects the fuelling across the entire fuel map. You reduce the pressure to alter the AFR on boost in the top end and it'll screw the AFR everywhere else.
It's like using a broadsword for removing someones appendix instead of a scalpel.
toyokid
Re: Fuelling
Post by toyokid »
Marf wrote:
toyokid wrote:
Marf wrote:
REALLY bad idea.
Why?
It has been proven to work with a standard ECU
on a rev 2.
Marf
Post by Marf »
Adjusting base fuel pressure WILL affect the fuelling across the board, on boost, off boost, low revs, high revs, EVERYWHERE.
Reduce it and you lean out across the fuel map, increase it and you'll richen the entire fuel map.
It's using a sledgehammer to crack a nut, a total and utter bodge.
But hey, it's "proven", so believe what you want. :thumleft:
:roll:
djpkins
Post by djpkins »
popshe...
nitric4k
Post by nitric4k »
I asked about one of these and was advised against it, for the above reason :)
so it will be standalone for me to come :)
djpkins
Post by djpkins »
lol...love that bug man...gonna get me every time :thumleft:
Super_red
Post by Super_red »
Marf wrote:Adjusting base fuel pressure WILL affect the fuelling across the board, on boost, off boost, low revs, high revs, EVERYWHERE.
:roll:
Adjusting the base fuel pressure will yes but what about a rising rate FPR? this will only start to increase fueling when boost is applied so off bost and low boost will remain the same. You can use a wideband to set up the additional fuel pressure and as long as the base pressure is the same it wont effect the cars off boost running. Reducing AFR by increasing fueling.
wont help with ignition retard though.
bobhatton
Post by bobhatton »
:roll:
How do you think the stock FPR works?
