Not much to it. Two bolts to each wing then 4 or so bolts from underneath the skirt to the sill. rear triangle is separate and slides under the front section
Oh and depending on what body work's been done the bolts to the wings may or may not have floating rather than fixed nuts which you'll need to get a spanner on
