Coolant leak testing with normal water
nutter
Post by nutter »
Hi,
I'd like to test my coolant system for leaks before i put my new toyota stuff in. Would it be ok to fill the system with water and run it for about 10-15mins to check for leaks? I could then flush the water out and but the good stuff in?
thanks
User avatar
Lauren
Re: Coolant leak testing with normal water
Post by Lauren »
Yep of course, doing that will cause you no probs.
nutter
Post by nutter »
Great, thanks Lauren!
^Trickster^
Post by ^Trickster^ »
Mine hasnt had any coolant in for about 5 months, i only ever use water, without antifreeze too, good job its not parked outside in the cold haha
Graeme
Jon Bradley
Post by Jon Bradley »
trickster arent you runninng a risk or corroding things that way??? Anti-freeze/coolant has a lot of corrosion resisting chemicals in it that are pretty important!
And nutter yes its a good idea anyway to fill up with water and let it run then flush it out - will help to get rid of any grime thats built up in there
^Trickster^
Yeh your right, just the last few months ive had it apart and together more times than anything, starts to get costly on coolant! once its all sorted ill flush it and put some in.
Graeme
