Mirror removal
richbay
Mirror removal
Post by richbay »
Am i right in thinking that to remove the wing mirrors all you need to do is remove the plastic trim ( being careful not to break the plastic clips, dooh)
then just remove the visible screws and off comes the mirror , as i have done this and it will not shift, is there something i am missing or and i not giving it enough force to remove it ?
thanks
PW@Woodsport
Re: Mirror removal
Post by PW@Woodsport »
It falls off when all 3 screws are removed, therefore you must still have at least one screw still in.
richbay
Re: Mirror removal
Post by richbay »
no i have removed the 3 screws and it would not budge, perhaps a bit more brut force is required
PW@Woodsport
Re: Mirror removal
They literally fall off when the screws are out, perhaps someone has bonded it on.
richbay
Re: Mirror removal
Post by richbay »
yes i am starting to think along those lines, bu88er...
elbon50
Re: Mirror removal
Post by elbon50 »
richbay wrote:yes i am starting to think along those lines, bu88er...
What's the problem with the mirror Rich ?
(Other than the obvious)
Peter
richbay
Re: Mirror removal
Post by richbay »
no problems with them, i just want to colour code them
elbon50
Re: Mirror removal
Post by elbon50 »
richbay wrote:no problems with them, i just want to colour code them
Can you mask up around them & spray them in situ ?
Peter
