Chris wrote: ↑Wed Feb 01, 2012 9:37 pm
You don't need the loom as you can wire it at the ecu instead.But you need the immobiliser ecu, and reader from the ignition barrel of the rev 4.
The car I wired in ran without the key.
Might of been a faulty immobiliser ecu though so cannot guarantee it will run without the key.
Basically, you wire the immob ecu, key reader etc at the ecu.And tape the key to it if required.
