A mechanic told me the cheaper 95 Ron stuff is better to use as it's what these cars are designed for.
james123 wrote:Just a quick one..
Which petrol is best to use???
A mechanic told me the cheaper 95 Ron stuff is better to use as it's what these cars are designed for..
I've had no problem running the 99ron stuff
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming'stop raping me'
Jimbo_Jet wrote:I suffer noticeable pinking in mine with 95 RON if accelerating hard while the engine is under 3000 revs, especially if going up hill and so adding extra stain.I switched to Tesco 99 and the problem vanished and the car certainly
'feels' a bit more perky on 99 but that could be in my head
However, I've noticed no benefit in MPG to speak of.I generally mix 99 and 95 now to get a similar result.
PW@Woodsport wrote:Quite surprised by some of the comments made, my experience has always been that using 95 ron on a Mk1 with stock timing makes it pink, switch to 97 and the pinking goes away.I only use 97 or 98 in my Mk1, i can feel the engine running better, maybe that's the mechanic in me, but when i've had to use 95, when there was no other choice, it pinks.
In my opinion 97 is the one to use on stock timing.
oukie wrote:Without doubt my car runs way better on V-power, its all I use but hey my car is a toy so cost is not a problem as I don't use it for work etc.
JMR_AW11 wrote:Just to complicate things even further, the ignition timing map is more advanced on a mk1a at high rpm/load.This is the
'little' ECU 89661-17030.
