After a few minutes it worked.
When i got home i changed the battery in the fob.
This morning i go out, use the fob and the alarm goes off!
After 30 seconds it stops and i can get into the car.
But the ignition is still immobilised.
Fob will lock and unlock the car, interior light comes on when car is unlocked.
Today i read on the internet that some fobs need to be paired up again with the main unit after changing the battery.
It's a Microscan immobiliser, i didn't fit it nor did the previous owner.
But doesn't seem to be a top of the range model as it has no motion sensors etc fitted.
Seems to need a key to pair the two units again or to disable it.
Will try and ring Microscan tomorrow and see if there's another way to pair these things up.
If they can't help, i may have to remove the whole immobiliser.
It can only be immobilising the ignition as i can start the car by bump starting it.
But that's not practical.
I got this wiring diagram from there site:
Seems to be fairly easy if i've only got to reconnect the ignition wire where it's cut in the diagram.
But the big question is.
