[Mk2] [NA] Crunch from 4th-3rd Pic needed !
stace110
Post by stace110 »
Hi all as above, ive been reading a few threads and im under the impression i can change a rubber on the gearbox. Is it possible for someone to put a pic up of what i need to change please and some info of the new part .any help would be great.
stace110
Re: [Mk2] [NA] Crunch from 4th-3rd Pic needed !
Post by stace110 »
Sorry its a 1996 rev 3/4 ?
stace110
Post by stace110 »
bump
Peter Gidden
Post by Peter Gidden »
Sounds like 3rd gear synchro to me.
Not sure what you mean by "changing a rubber on the outside of the gearbox".
stace110
Post by stace110 »
Yeah i read on some post that you could change a rubber on the linkage.Also while im at it is the gearbox oil the same as the diff ?as in if i have a leak on the diff the gearbox level will drop aswell or is that just a retarded question .....
Peter Gidden
stace110 wrote:Also while im at it is the gearbox oil the same as the diff ?as in if i have a leak on the diff the gearbox level will drop as well..
Yes, the gearbox shares the same oil as the diff.
stace110
Post by stace110 »
that might explain the crunch ....my diff is leaking ...
stace110
Post by stace110 »
can i use 80/140 heavy duty oil as a replacement
Peter Gidden
I certainly would not.
stace110
Post by stace110 »
lol 75/90 it is then
Century Motorsport
Post by Century Motorsport »
Agree with Peter, sounds like synchros are on their way out.
If you need a box build we are only down the road from Rugby!
stace110
Post by stace110 »
How much for removel and rebuild and refit ?
ToyotaTosh
Post by ToyotaTosh »
have you changed the gear linkage bearings ? 9 quid !! :thumleft:
WAKEY MR2
Uprated gearshift bush kit
Post by WAKEY MR2 »
Hi bud is this what u mean ? Uprated gearshift bush kit ?
http://www.gtschris.com/store/comersus_ ... &curPage=3
GTSCHRIS is good for lots of parts :D
ToyotaTosh
Century Motorsport
If it's crunching then those won't do anything to help it unfortunately.
