Harold wrote:If you can't afford to get the car trailered, how are you going to afford to fix the car if the block does crack? I don't really understand, why not just stick at 500hp and enjoy the car?
Lol cheers Harold! knew i could rely on someone to pick up on this!!
Basically, when i started building this car some 5 years ago it was with the intention of hitting 600fwhp and i will eventually use it up santa pod once i am certain its all running good.
Its not my daily driver, infact its only done about 3,000 miles since i purchased it!
The reason i cannot afford a hire car and trailer etc at the moment is because i am near the end of doing my pilots license and i need to make sure i have enough wedge left so as i dont go skint the day before my test! This is my main priority before the car.
At the same time tho, the engine build is practically done after 4~5 years of long long days and nights of building/designing/swearing etc and tbh i just want to see if i have achieved my goal!
-I can afford the cost of the mapping session
+ fuel
but hiring a 4x4 and trailer on top will almost double the costs, which i cannot risk atm.
If the block goes crack then that is not a problem, so long as i can get it home somehow.
It will then just sit in the garage for another 6 months or so whilst i strip down the bottom end and slowly upgrade it to a 5sfe.
It needs tuning now as i need to make use of the cold air temps and also if it does go bang, i might have just enough time to get it back up and running again before the
'12 summer ends!
Steve, dont worry mate, soon as i see it survive the dyno and still drives home without a wheel falling off or what not, that gives me enough confidence to give it a blast here and there
;D
greeny, its a early rev3 block 1994
-iirc this is the worst one? but yes i have had it sleeved and the pistons im using are only
.5mm oversized so the overall wall strength must still be considerably more than a stock size 3sgte? I remember yours cracking on the outside, above the A/C mount wasn't it?
