What manifold are you running?
mihogal12
Post by mihogal12 »
Guys
Just a discussion about what manifold set up u guys are running?
I know here in Irl all the ae86 fellas are big into their stainless manifolds etc.
Has anyone any experiece with them on an aw11 and if so what are yer opinions?
All opinions welcome - Good/bad!
User avatar
Lauren
Re: What manifold are you running?
Post by Lauren »
I would go as far to say that hardly anyone has a non-standard manifold on their MR2. Most however do fit stainless steel exhaust systems, invariably of the Magnex/Mongoose type.
I know on AE86's it's the other way round, but I would say there is a bigger global market for AE86 goodies.
LimeyMk1
Post by LimeyMk1 »
I had a Trust/GReddy mild steel tubular manifold on my Mk1, coupled to a mongoose system. I'm not sure if it did much for the power as I didn't have the car Dyno'd while it was on the car, the butt dyno didn't tell me much either. :lol:
mihogal12
Post by mihogal12 »
Lauren wrote:I would go as far to say that hardly anyone has a non-standard manifold on their MR2.
I have noticed this alright. Its funny how different cars with the same engines have different modification styles.
I suppose its a "Looks" thing on the ae86 since people can see the manifold and it makes for nice astethics.
elbon50
Post by elbon50 »
Also the MR2 4A-GE manifold is quite an efficient design I think
Had a £500 quote to have a performance manifold made
Not sure its the best use of my 500 :?
May be interested in a SC manifold because it has a drilling & studs for an oxy. sensor
Peter
CecilWard
Post by CecilWard »
elbon50 wrote:May be interested in a SC manifold because it has a drilling & studs for an oxy. sensor
Forgive my ignorance Peter, but how do you exploit that? Needing a replacement ecu?
LimeyMk1
Post by LimeyMk1 »
Handy if you're going for an aftermarket ECU such as Megasquirt. :thumleft:
This is the same as my ol' Greddy:
http://www.rhdjapan.com/trust-greddy-tr ... aw11-54388
Placement of the Lambda sensor's a bit crap IMO.
aw11rally
Post by aw11rally »
We've got a custom (Richard Macer / RMS / RM sport I think) 4-2-1 in mild on the rally car (mild is the better material for manifolds, more resistant to thermal cracking, unless you can afford inconel that is).
I've never tried a standard manifold on the same engine so couldn't compare scientifically. BUT if SC engines can push close to 200bhp on standard kit I doubt you need to change your manifold unless you're building a 160bhp+ NA engine.
I have got figures for our manifold against a formula Atlantic manifold on the same engine. Although the dyno's and gearbox etc were different the results were very similar. 167bhp(rear wheels) with ours, 198bhp(flywheel) with the formula Atlantic manifold.
I've had a few quotes for a copy of our manifold and they all come in at about £600 for the first one (a jig needs fabricating) then less for any additional copies required.
elbon50
Post by elbon50 »
I have a Megasquirt ECU Cecil
Havn't got it working yet, but hopefully soon
It can use an oxy sensor
Peter
PS You have a PM re a gearstick extender
SuperRedMR2
Post by SuperRedMR2 »
I looked at a stainless manifold and was quoted £500 + VAT - the materials don't even come to £100 so a bit of a rip off really.
I keep toying with the idea of getting one made at work but what with my own engine problems and being flat out at work I just haven't got round to it.
aw11rally
Post by aw11rally »
SuperRedMR2 wrote:I looked at a stainless manifold and was quoted £500 + VAT - the materials don't even come to £100 so a bit of a rip off really.
Expensive yes but I wouldn't say it was a rip off. If I was making manifolds for a living I'd be wanting a couple of hundred quid profit for a days work. A lot of hours would go into scratch building then tig welding a manifold. Just the two flanges would take a good bit of time on a milling machine.
