What dose c/opn relay in the engine compartment fuse box mean
asbestos
Post by asbestos »
What dose c/opn relay in the engine compartment fuse box mean or what dose it control,
thanks all.
gazrev1tubby
Re: What dose c/opn relay in the engine compartment fuse box mean
Post by gazrev1tubby »
The circuit opening relay is for the fuel pump
Peter Gidden
Post by Peter Gidden »
gazrev1tubby wrote:The circuit opening relay is for the fuel pump
Correct.
More specifically, it has a double ended coil. One end pulls the relay in when cranking, engaging the fuel pump.
When the engine fires, the first coil is switched off (since no more cranking), but the ECU pulls in the other end of the coil, re-engaging the fuel pump.
If the engine is stalled but igntion is still live, ECU will terminate it's signal to the relay, causing fuel pump to swtich off. e.g. in event of accident.
