Mk1 Short Shifter, Are these cheaper ones any good?
un1eash
Post by un1eash »
Hi there, Are these short shifters any good, anyone had any problems with them?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
Will be getting one unless theres a reason i shouldnt.
mr2mk1chick
Re: Mk1 Short Shifter, Are these cheaper ones any good?
Post by mr2mk1chick »
I've looked at these too. I also wondered if they're any good.
the only thing I can add is that I've bought other stuff from this ebayer and have had no problems and fast postage.
feral4mr2
Post by feral4mr2 »
a short throw/quick shift kit is very easy to make yourself for next to nothing.
i made mine from a small peice of aluminium sheet and some washers, might be a bit ghetto but works well. :)
http://www.mr2oc.com/showthread.php?t=111458
stevenb
Post by stevenb »
What is the normal cost of purchasing one rather than having to bid on ebay?
How easy are they to install? They look simple enough in kit form but I don't want anything on my car to be disrupted just to fit one of these.
emartou
Post by emartou »
I have had 1 fitted to mine for over a year. and i still appreiate it now. I see other MR2's with long sticks which i think now look odd. It was easy to fit, and took just over an hour. I also fitted the original rev3+ gearknob.
The only difference between the mk1 and mk2 is the interior trim around the shifter. once that is removed then the the mechanism is the same.
The price is really cheap, a b+m would set you back around £150.
firstmk1
possible cheaper option
Post by firstmk1 »
I've had one in my car for about a year now and think it's great. I've since been told that a Mk2 stick can be used as a quick shift but you may need to check this.
User avatar
Lauren
Re: possible cheaper option
Post by Lauren »
firstmk1 wrote:I've had one in my car for about a year now and think it's great. I've since been told that a Mk2 stick can be used as a quick shift but you may need to check this.
Yep Rev3 stick is shorter you can use that.
sadako
Post by sadako »
I've just had a Mk1 stick cut down and welded with the thread on the top. Change is smoother and cooler than haagen daaz...
User avatar
Lauren
Post by Lauren »
sadako wrote:I've just had a Mk1 stick cut down and welded with the thread on the top. Change is smoother and cooler than haagen daaz...
You could easily cut a bit off the stock gearstick then just use a stock and die and thread a little more.
shish
Post by shish »
if you want something real cheap:
feral4mr2
Post by feral4mr2 »
yea but also make a plate and use some washers to drop the shift linkage set-up down lower too. (as i did in the thread i linked).. :)
superchargedsam
Post by superchargedsam »
i have the original drop plate and short shift kit from the states if anyone wants any pics am sure it would be easy to fabricate a kit up if you had the right kit to do it as its nothing complex, I will take pics soon anyway as I will soon be fitting it as I got it 4 years ago ! DOH !
jasper
Post by jasper »
It's worth bidding on Ebay, I got mine for £22, just fitted it today. It didn't take long at all. The hardest part was taking out all those screws from the centre console....! The seller even emailed an instllation guide. I did find the new bolts a tad too long though so I had to cut them down. Not used it in anger yet, just a small test drive. It felt sweet though, I'll keep you posted....!
stevenb
Post by stevenb »
jasper wrote:It's worth bidding on Ebay, I got mine for £22, just fitted it today. It didn't take long at all. The hardest part was taking out all those screws from the centre console....! The seller even emailed an instllation guide. I did find the new bolts a tad too long though so I had to cut them down. Not used it in anger yet, just a small test drive. It felt sweet though, I'll keep you posted....!
have you got a pic of the item jasper?
jasper
Post by jasper »
Steve, It's exactly as the one in the link above.
stevenb
Post by stevenb »
I see.
Whats the gearknob like....it looks a little max powery to me....is it a decent one?
jasper
Post by jasper »
Seems ok to me. Nice and chunky...
RedWitch
Post by RedWitch »
I fitted one of these yesterday, didn't come with any instructions but straightforward enough, took about 1 hour all through.
My only complaint is that the stainless steel knob isn't quite straight - but wan be sorted out with a dob or Araldite.
gordy.r
Post by gordy.r »
Ive got that exact short shifter kit that you were looking at, it really is a good buy and looks the dogs danglies when its install (took about an hour). I got mine for £30 quid i think it was.
Loks even better when you get one of Rhonsmr2 new leather gaitors round it too!
hope you managed to get it!
gordy
