Has anyone had any experience with these? My rad has a hole in it pretty sure a stone flicked up and pierced it.
So It needs replacing. now there are these on ebay
http://www.ebay.co.uk/itm/TOYOTA-MR2-SW ... 1c20132edc
I'm wondering if they are any good? To me they look ok although the sensor hole is blocked off is this important?
Then there is the ones MR2-ben does
http://www.ebay.co.uk/itm/NEW-EXTRA-COO ... 3f0b370462
Which i'm more comfortable with trusting so what are peoples thoughts.
Alloy Radiators
Re: Alloy Radiators
When my rad goes down, I'll be replacing with an alloy item and twin spal fans
Re: Alloy Radiators
RedMR² wrote:When my rad goes down, I'll be replacing with an alloy item and twin spal fans
I think i'm sold on the alloy idea.. because it weighs less than half of the standard one but which one do you think is better..?
The top ebay one there is 100% alloy but has the sensor blocked over.. Mr2 ben's one has a Alloy core and mild steel tanks either side.. I'm leaning towards Mr2 ben's one.. I just don't know.
Re: Alloy Radiators
Just ordered the MR2-Ben one as it has the hole for the sensor..
Re: Alloy Radiators
i've got this one (same as mr2-ben's one), shame they set the bleed valve in the wrong place so you can use the pipes to bleed it like stock
http://www.ebay.co.uk/itm/TOYOTA-MR2-Mk ... 41572dfe0e
Re: Alloy Radiators
steve wrote:i've got this one (same as mr2-ben's one), shame they set the bleed valve in the wrong place so you can use the pipes to bleed it like stock
But it is ok other than that right ?? because i've just ordered one..
Re: Alloy Radiators
Radtech Racing in cannock, if you want a top quality rad
Mine cost me £400
Re: Alloy Radiators
Mine cost me £400
I'm not sure I can warrant £400.. I'll have a look at the Mr2-ben one when it arrives on monday.
Re: Alloy Radiators
Yea it is expensive, but perfect pattern copy
Re: Alloy Radiators
Drifter wrote:Yea it is expensive, but perfect pattern copy
It does look lush If i had the cash I would get one of those.
