there is a knocking sound from low down in the drivers side rear wheel arch. ive replaced the drop bar and the top mounts but its still there. it seems to get less when the car has been running for a while. any suggestions its really annoying me.
Alright mate have the same problem as you took it to millway in andover basically all drop links are fine no worn bushes, they were stumped! Quite hard to test on ramp managed to put car back on ground and found that it was the shock making the noise on the extension so decided to replace them. having work done 2mrw so will let you know.
