Dropping boost and lumpy running.........
AdamR
Post by AdamR »
A problems developed on my Tubby, and tbh its pi$$ing me right off!!
Last couple of days it wont hold 1 bar of boost - it'll build to it fine, but then after 5k rpm, it starts to drop off down to .75 bar.
Also when its cold its runs quite lumpy and hesitant :(
Any suggestions?
AdamR
Re: Dropping boost and lumpy running.........
Post by AdamR »
UPDATE
It seems the problem is intermittent, as yesterday it was fine when I drove out, parked up, when driving home wouldnt boost past .75bar again.
Any ideas? - I'm currently suspecting a boost controller problem (its a greddy profec e01) as a friend had something similar a while ago.
Driftlimits Performance
IMOC Affiliated Company
Check the vsv isn't plugged in.
I had my clutch done a while ago, and Mr.Clutch kindly plugged it back in for me. It would boost up to my Greddy (profec B2) settings of about 16psi, then drop to 13psi.
AdamR
Post by AdamR »
Cheers!
Wheres the vsv located, and whats it look like?
Thanks in advance
Adam
