1/
2/
Peter
Limeymk1 wrote:Stock one's about 12kg from what I remember, not sure about the Fidanza, LOTs less.![]()
Edit: 4.09kg according to Fensprout website.![]()
kherseth wrote:Anything is possible, from memory the F1 cars have no"flywheel", instead it relies on the weight of the crankshaft/rods/pistons and clutch.
Result is of course that you need very high idle to keep the engine from stalling.
Also, in order to get going, delicate clutch handling and even higher revs would be needed.
Pure guesswork, but when the flywheel is down to 4kg, would it not be just as useful to upgrade to lighter crank/rods? I guess the cost would be comparable to having a lighter flywheel custom made.
elbon50 wrote:Limeymk1 wrote:Stock one's about 12kg from what I remember, not sure about the Fidanza, LOTs less.![]()
Is it possible to go lighter than 4 Kg?
Peter
Limeymk1 wrote:elbon50 wrote:Limeymk1 wrote:Stock one's about 12kg from what I remember, not sure about the Fidanza, LOTs less.![]()
Peter
You can get lighter flywheels for the MK1, down to 2 or 3 kg from what I recall but they cost a fair bit more.
elbon50 wrote:Thanks Limey
Lots of extra cost for very little gain perhaps?
Very light F/W would also mean rough tickover I should think?
Peter
stenky wrote:isn't heat dissipation with lightweight flywheels a problem?
Limeymk1 wrote:stenky wrote:isn't heat dissipation with lightweight flywheels a problem?
Shouldn't be with the Fidanza as it's a solid flywheel.Only difference is it's mostly ali.
The Chromoly steel ones are usually holey so not a lot of material for heat dissipation, so maybe.![]()
stenky wrote:well, i reckon that fidanza has calculated it well and the heatmarks do not alter flywheel's durability(although any heat treating does change material properties of metal, no doubt about that).
what does trouble me is fact that, the excess heat a stock flywheel has to absorb and lightweight might not, could transfer way further to the crankshaft, degrading oil faster, or in the worst case, burning it up and damaging shell bearings-crank badly.
any opinions on that? i am really keen on getting fidanza
also, i believe that paddle clutch produces less heat than organic one, so the picture above is probably the least that could happen to the flywheel.
Fab4MR2 wrote:Here are some real life weight measurements for the 4agze components from when I recently rebuilt my MKI SC.
Oem MKI SC 4agze flywheel: 5930 gm;
Fidanza MKI SC 4agze flywheel: 4505 gm;
Basirk wrote:I did have a slight issue with mine.
After the engine had warmed up, when I pulled up at some lights and put the clutch in then the engine would sometimes stall.There could have been an issue elsewhere of course.
