I want to tune a NA 16v 4AGE engine.
The way I was hoping to get to this power was going to be the following.
uprated cams, springs and valves
more efficient exhause manifaold
Forged crankshaft, hight compression pistons and lighter forged conrods.
ITBS
lightened flywheel
hight output fuel pump
Ok this is where I'm asking for help and advice with the technical side, I have no idea about the engines details.
I get the basics of how they all fit and work together but when I look for example a crankshaft it says
Max HP
Is that stroke size right for a standard MR2 4AGE? because it can handle a greater power can I make the engine rev higher?
As for pistons, what sizes do I need? How do new pistons increase pressure? If I have higher lift Cams and taller pistons will my engine eat itself?
I'm sorry if this sounds like a stupid post but this is going to be something I plan to build over the next few years for putting in the MR2 when it's rebuilt.
I'm looking to do all the work myself just to see if I can do, please give me any advice possible.
Liam
