basically I have had an auto electrician out to the car who told me that it was the alarm that was stopping the charge getting to the starter solenoid, so I got an alarm specialist out who checked everything and told me its not the alarm that's stopping the signal getting through he traced the wire back and found that it was the starter relay stopping the signal, so I've changed that but still there is no ignition, I know the starter motor works as I've had that out and tested, the only wire going to it that does not have a charge when the ingition is turned is the one that goes to the starter solenoid, someone please help I have a week to get the car up and running again and I am so close now I can smell it.
Its a rev 4 NA engine with a Rev3 loom and ECU.
if there is anyone in the Yorkshire area if you could come and help me diagnose the problem and even solve it that would be awesome!!.
Thanks in advance
