Rev 1 to Rev 3 Gearbox
samu23
Post by samu23 »
Hi
After buying a new speedo sender to try and fix the problem on my rev 1 turbo, it still isnt working, the blue speedo drive inside the gearbox seems to be broken.
So ive decided to replace the gearbox, ideally id like to get LSD whilst im at it, so whats the situation swapping to a rev 2/3 gearbox and getting a speedo sensor to the dials? Also if im going from non-lsd to lsd will i need new driveshafts etc?
Thanks in advance!
Sam
alanmr2turbo
Re: Rev 1 to Rev 3 Gearbox
Post by alanmr2turbo »
Just use you cable sender in rev3 box and non LSD shafts are ok to fit into a LSD box
