[Mk2] [Turbo] Turbo Oil feed block adaptor what size ?
asbestos
Post by asbestos »
Im just fitting a top mount manifold and a garrett turbo to my rev 3, where can i get a oil feed block adaptor to fit the new stainless hose which i am running up to the turbo, i beleive the hose fitting is a 3 AN ( whatever that is), dose any one know the size of the fitting that goes into the block, or point me in the right direction,
thanks all.
calum4492
oil
Post by calum4492 »
the oil feed adapter to the turbo from the block is an m18 - 1.5 and i use an an4 for the feed
u could probs get 1 off the bay
i got mine from think automotive 020 8232 3523
was about 12 bucks or so defo dont buy the berk 1 its like 40
Shmed
Re: [Mk2] [Turbo] Turbo Oil feed block adaptor what size ?
Post by Shmed »
They are different sizes on the rev 3 block I think.
January 2014
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
Still in the garage...
calum4492
ada
Post by calum4492 »
u could well be right but im sure its only the dump pipe adaptor that screws in2 the sump that is diff
Peter Gidden
Post by Peter Gidden »
Rev3-5 turbo oil feed outlet in block is M12 x 1.25.
