[Mk2] [NA] Auto to manual conversion?
_john_
Post by _john_ »
I've seen a nice MR2 for sale, but it's an automatic.
Is it a costly procedure to change it to a manual? I'm hoping it'd just be a case of doing a straight swap?
Can anyone fill me in on how much a manual box in good condition should cost?
The car is a rev 3.
Cheers!
foxy-stoat
Re: [Mk2] [NA] Auto to manual conversion?
Post by foxy-stoat »
Too much grief and a lot of work to change over to be honest. I would just buy a manual one to start with.
You would need:
Good manual gearbox (upto £200)
Maybe drive shafts but dont know if they are the same as auto
Clutch - £55
Flywheel - £25 secondhand?
Rear clutch pipework
Slave cylinder
Manual peddles
Gear linkage cable
Front clutch slave cylinder
Engine ecu or moddifing the auto ecu
Clocks
And anything else I have forgotten.
Probably a weekends work with stripping out a lot of interior exterior parts and fingers crossed it will work ok.
We ALL make mistakes !!! :)
kayjay0_7
Post by kayjay0_7 »
foxy-stoat wrote:Too much grief and a lot of work to change over to be honest. I would just buy a manual one to start with.
You would need:
Clutch - £55
Slave cylinder
Manual peddles
Gear linkage cable
Clocks
it's one nightmare of a job converting from auto to manual, the most difficult part is running the clutch line underneath the car
did mine when I converted from auto to manual V6
Barnz
Post by Barnz »
_john_ wrote:I've seen a nice MR2 for sale, but it's an automatic.
The car is a rev 3.
Cheers!
Hi John,
If you don't go for the swap can you pass the ad on to me pls? I'm looking for an Auto rev3+ next thanks
