Oil pressure question
Tellso
Post by Tellso »
Hi guys, on a tubby what kind of oil pressure should i expect from normal everyday driving - by normal i mean taking it moderately easy :)
I have an oil pressure gauge and it usually sits around 3-3.5bar when in motion. And when idling drops right down. I would expect it to drop but it practically hits between 0 and 0.5 mark as a rough guide. Is that right or should i be worried?
alanmr2turbo
Re: Oil pressure question
Post by alanmr2turbo »
cheap gauge and sender?
if oil pressure was a problem i think the oil light should come one
Marf
Post by Marf »
Operating oil pressures should be in the BGB. Idle I'd expect to see 1.5-2bar at least.
alanmr2turbo wrote:if oil pressure was a problem i think the oil light should come one
Don't bank on it, my experience of the senders for low oil pressure is that they only trigger when its REALLY low, like 0.3bar or something, i.e. engine lunching territory!
greeny
Post by greeny »
Marf wrote:Operating oil pressures should be in the BGB. Idle I'd expect to see 1.5-2bar at least.
Yup less than 7psi iirc.
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
dantheman
Post by dantheman »
http://www.lovehorsepower.com/bgb/mecha ... system.htm
idle oil pressure: 4.3 psi or more
at 3000 rpm: 36 - 71 psi
Tellso
Post by Tellso »
Brilliant, thanks guys. The gauge was a pretty damned expensive one so hopefully accurate. Ill check my figures... Great help :thumleft:
Tellso
Post by Tellso »
.... so based on those figures in PSI, my readings seem about correct (1Bar = 14.56PSI)?
Only i have an indicator that flashes red when my gauges go over or under a certain amount and its been set to go off or flash like mad when the oil pressure drops too much which obviously only happens at idle. I guess theyve just set it too low. It still runs/idles perfectly :D
dawesy
Post by dawesy »
i see 1.5-2.0bar at idle (engine warm) and 3.5-4.0bar on cruise (2.5k-3.5k rpm) after a spirited drive it does drop though, the apexi turbo is oil cooled so that may be the reason for this,usually goes no lower than 2.8bar on cruise though, idle goes down to 1.0-1.2ish @900rpm)
cold figures are much higher though the tell tale on the spa gauge im using sees oil pressure has peaked at 7.0bar!!
