i have 780cc Delphi injectors and a HKS fuel rail
does anyone know the diameter diffrence between the Delphi and HKS injectors
im aware i have to bore out the HKS Rail
Iirc
Basically two types,14mm and 11mm
the rev 2 wolfkatz i had was 14mm so were the injectors(Delphi).
some fuel rails like the obx and some Hks and sard are 11mm,
you will need to double check though.
steve
