The fluid is fine so not sure what it can be?
Harold wrote:The power steering is activated via a ring passing through a sensor on the steering wheel boss, it is also activated by driving over 10mph.If you have an aftermarket wheel then it may not have this ring, this is why it's turning off when you are parking, as you're driving at less than 10mph and the sensor isn't triggered.
Do a search on the forum and you'll find a few topics about this very image.
Johnr32 wrote:Harold wrote:The power steering is activated via a ring passing through a sensor on the steering wheel boss, it is also activated by driving over 10mph.If you have an aftermarket wheel then it may not have this ring, this is why it's turning off when you are parking, as you're driving at less than 10mph and the sensor isn't triggered.
Thanks Harold, yes, I do have an aftermarket steering wheel.![]()
Johnr32 wrote:Strange but shouldnt it always be heavy? its only sometimes(rarely) heavy when doing parking maneuvers.
