Hi I'm new, just purchased my second blue mr2 1997 T-bar uk model after I had withdrawal symptoms when my last beloved 1991 red one needed
£500 of welding to get through the mot so I just sold it to a friend for scrap.
Anyway with this one I notice water poring out of the bottom front right drivers door or rubber
& to a lesser extent the passengers door when I open them after a shower
Do you know if it is normal or where I start to look for how it's getting in?
The abs light also came on only 5 miles after I picked it up
& the previous owner said he saw it to but it went away after he topped up the brake fluid.
Any upon further investigation using the diagnostic paperclip method I get a 35 error code
- the rear drivers sensor also meters open circuit at the plug.
if anyone knows where I can get one or if they are easy to get out as I hear they get stuck in or break off!
