can anybody tell me what stages of tuning you would fit a multi plate clutch, and is it true that these are unsuitable for everyday driving ? or should I stick to single plate clutch ? I have engine stripped and clutch plate material is worn, so needs replacing. I will be fitting a light weight flywheel & there is a greddy td05sh turbo replacement that will need fine tuning . so I need advice on what type of clutch I need and how they work. thanks spen
