turbo oil filters
Chris \'aka rustboy\' Amm
turbo oil filters
Post by Chris \'aka rustboy\' Amm »
do MR2 turbo's use the same filter as a uk NA MR2? is there any difference in a rev1/2 and rev3 oil filters or will they all fit?
doing the dreaded oil change myself today if i can, anyone got any oil recomends? i'm thinking 15w50?
cheers people
DannyW
Re: turbo oil filters
Post by DannyW »
i'd like to know the filter question too as i'm going to do mine tomorrow.
Lee @ 3S Service Centre
Post by Lee @ 3S Service Centre »
all the catalogues show different part numbers so i guess there is some small differences.
Rory
Post by Rory »
Turbo oil filters are longer. As far as I know the NA filters fit Tubbys but they deffinatly are different.
Rory
Grajey
Post by Grajey »
Turbo filter 90915-10004
N/A filter 90080-91045
Drain plug gasket 90430-12031
Grajey wrote:Turbo filter 90915-10004
are these toyota part numbers? if so that's excelent! cheers :D
Mikejc
Post by Mikejc »
hey Chris.
As mentioned the tubby has a different filter ti that found on the N/A. Althugh teir are two different serial numbers for the turbo verient, i'm led to believe by Toyota them selves that they are however the same, ie will fit all revisions :wink:
As for oil choice. I was using Mobile 1 15w50, but it was brought to my attention that the first number of 15 is a little high for this time of year. This leads to extended warming up times hich in turn allows more wear on the engine during this period! I'm now using Silkolene 10w50. I've noticed that my engine now reaches running temps a lot quicker now and also seems to rev with less effort. Highly recommended :wink:
Mikejc
cheers top advice mike!
will get the oil and filter tomorrow now as now one answered me in time :(
User avatar
Lauren
Post by Lauren »
Interestingly the same oil filter will fit all 4AGEs too.
The longer one is the one you want ideally. This is what i used to use on my SC, though its had the shorter one too with no problems.
I just picked one up this afternoon from MrT for my 86NA was £8.23 all in. Don't forget the sump plug washer when you get the filter.
Mikejc
Post by Mikejc »
No problem Chris.
Try this place for you oil needs (01209-215-164) and ask to speek to a chap called Guy. He knows more about oil than anyone i've ever meet and is a real nice guy (no pun) to boot! lol
Mikejc :wink:
The Morris
Post by The Morris »
I used a standard celica one last time and it fitted.
JohnnyC
Post by JohnnyC »
Mikejc wrote:As mentioned the tubby has a different filter ti that found on the N/A. Althugh teir are two different serial numbers for the turbo verient, i'm led to believe by Toyota them selves that they are however the same, ie will fit all revisions :wink:
Have you got a foreign keyboard or something? :lol:
Yes, an NA filter will 'fit' on a turbo engine, but I'd get the one specifically for the turbo. And Toyota should stock these too as the 3S-GTE engine was found in the UK Celica GT-4.
Stef Derner
Post by Stef Derner »
The turbo filter has a bypass valve in case the filter should become blocked.
