The weirdest fault happened to me
Odin_S
Post by Odin_S »
1. key in ignition
2. Turned to ACC everything normal
3. Turned key to start engine, everything dead
No lights no nothing. :-k Luckily i left my battery charger at work plugged it in, car started as normal
The car has never done this before ( in fact has never not started) the volt meter said normal reading of 14.5 volts
Started today as normal too, thats really weird no warning at all, anyone help?
greeny
Re: The weirdest fault happened to me
Post by greeny »
Odin_S wrote:1. key in ignition
I'd check you're battery terminals are tight chap.
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
Steve-O 2007
Post by Steve-O 2007 »
also could be your alternator on its way out, I had something similar to this
Rogue
Post by Rogue »
greeny wrote:I'd check you're battery terminals are tight chap.
^^ This.
Odin_S
Post by Odin_S »
Thanks very much guys, put the fear of God in me when it happened :shock:
Rogue
Post by Rogue »
Odin_S wrote:Thanks very much guys, put the fear of God in me when it happened :shock:
Me too, the first time! I've had it happen loads on many different MR2s. Quite often it's because the posts are too small for the terminals and they don't grip well. More often than not it's the earth rather than the live that's affected.
Fourveesix
Post by Fourveesix »
Had a similar fault on the corolla.
Started fine, drove to the destination, went back to the car -click then nothing.
Turns out the battery had failed (was a genuine toyota item) and could only get a minor voltage reading out of it, replaced it, no more problem.
