[Mk2] [Turbo] mr2 rev2 engine into rev3 gt4
mr2barri
Post by mr2barri »
how much work is involved and what parts are involved to change a rev2 mr2 engine into a rev3 gt4? any help is appreciated
bri0905
Re: [Mk2] [Turbo] mr2 rev2 engine into rev3 gt4
Post by bri0905 »
By rev 3 gt4 do you mean st205?
If so isn't that going backwards, less power, paper head gasket, worse turbo, a head that doesn't flow as well??
96 Rev 3 Turbo, Done!
Razor04
Post by Razor04 »
don't feed the Troll's :lol:
mr2barri
Post by mr2barri »
well no iv got a fully forged rev2 engine at about 400bhp and precision 5431 turbo so its near brand new and it seems a shame to part with it when its done near no miles so im going to put it in a gt4st205 so i was wondering what parts and involvement was involved as far as i knew it was just a rev2- rev3 wiring conversion
RST
Post by RST »
Rev 1/2 SW20 is gen 2 3SGE and ST205 is gen 3 3SGTE so outwardly this seems a bit of a backward swap. If you're putting it back into an ST205 there would be a fair bit of reverse engineering though I'd imagine the mechanics would suit somewhere. It seems a shame to do it though. It's certainly not just a wiring swap, then I'm not sure what the ST185 charge cooler woild need to swap into an ST205 chassis -never been done I think. Most st205'er owners (ex one myself) like their gen 3's so not sure why you think a gen 2 would be better even if you have one spare.
irietuning
Post by irietuning »
You might need to get a scrap 3sgte from a st185 GT4 for some bits and pieces. I did it the other way around st205 to mr2. I needed a new crank pulley, cam belt cover, water inlet pipe and outlet housing. If you are using the chargecooler , you would need the st185 throttle body too. Cant remember what else off the top of my head
Irietuning whenever possible
