has anyone on here had water leaking into interior drivers side footwell
doesnt feel sticky to the touch so not antifreeze
the car is a sw20 t bar 98 can sit inside for hours no sign past tbar rubber
or screen edge must be up behind dash ?
has anyone had similar and been able to cure
thanks in anticipation
water leak problems
Re: water leak problems
hardly likely to be antifreeze mate
- the engine is behind you
maybe the windscreen leaking
jasongtr wrote:hardly likely to be antifreeze mate- the engine is behind you
The heater matrix is in front.
- IMOC Committee
I don't think the coolant in these cars feels any different from water.
It tastes very different though, ethylene glycol is very sweet to taste.![](./images/smilies/spacer.gif)
And yes, behind the glovebox is the heater matrix and aircon gubbins if you have it.![](./images/smilies/spacer.gif)
IMOC-UK
- the only club to win
'Best Club Stand' at JAE more than once, and twice in a row!
Have you checked that ther front T bat pipes arent blocked? They run down into the wing from the T Bar seal
On mine water was getting under the seals on their leading edge and then running down the inside of the piece of interior trim to exit unseen directly into the carpet.
New seals sorted it but as said it could be blocked drainage holes.
R.![](./images/smilies/spacer.gif)
R.
