forged pistons 86.5mm
eagle rods
arp bolts and studs
mahle bearings
fensport gasket
precision 5431 turbo
bmic with 3" pipework
iv been given a diagram off a freind but it seems a bit excessive any help is appreciated,cheers
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
^Trickster^ wrote:very partial throttle to pull some boost in should be fine, if you havent changed your injectors im assuming you changed to a td06 or something similar?
Graeme
swaggansway wrote:but wow![]()
they are expensive.
.is there any other way to keep an eye on knock?
