[Mk2] [NA] fitting rev3 centre panel to rev 2
Hi all just bought rev3 rear lights and centre panel.
Question is do i need some brackets to fit the centre? Or do i take them off the old panel?
Re: [Mk2] [NA] fitting rev3 centre panel to rev 2
is this a replacement rev 3 panel for a rev 3? Or is this a conversion for a rev 1 or 2?
The rev3 center panel has an L shaped black bracket either side that
is used to bolt the panel to the car.
There are no brackets to transfer from the early panel to the rev 3.
sorry should have put its a rev2 and ive bought rev3 setup but no brackets.
Are these easy to find? knowing my luck probably not
you will also need to dent the rear panel
(the metal behind the plastic centre panel) to clear the lights in the centre panel, the rev3+ shells have these indentations already done at the factory of course.
- IMOC Moderator
you will also need a longer key, the rev 2 lock sits miles in the hole, the rev3 lock sits flush with the inside of the panel
jasongtr wrote:you will also need to dent the rear panel(the metal behind the plastic centre panel) to clear the lights in the centre panel, the rev3+ shells have these indentations already done at the factory of course.
Some late rev2's already had this provision for some reason
deg61 wrote:sorry should have put its a rev2 and ive bought rev3 setup but no brackets.Are these easy to find? knowing my luck probably not
Very easy to find.
- IMOC Moderator
never even thought, i have a rev2 with rev3 lights/panel, i don't think i've EVER used the key to open the boot, i just use the handle inside the car
You can see them here...
http://trd2000gt.forumotion.com/t130-re ... removal-93
whereabouts in lancs are you - think I have a pair spare
Im in bacup near rochdale.
yeah have seen about denting rear panel.
will have to look for a lock.
Been in touch with the guy i bought them from to see if he has the brackets so just waiting for him to get back to me.
Cheers for your advise everyone
