inlet manifold
inlet manifold
On the inlet manifold there is a vacuum controlled valve, which operates 4 butterflies.
My question is what do they do and what are they receiving a vacuum from? BTW its an n.a 3sge
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
Re: inlet manifold
The valves
close
at higher rpm,
decreasing
the volume of the inlet manifold at higher rpm.
This gives the benefit of increased low/ mid range torque, and increased power at higher rpm through
'inertial supercharging' once the butterfly valves
close
It's called ACIS
- Acoustic Control Induction System, and is the main reason for the change in noise that your engine makes at higher rpms
http://en.wikipedia.org/wiki/Acoustic_C ... ion_System
EDITED cos I'm an idiot](./images/smilies/eusa_wall.gif)
It's called ACIS
Re: inlet manifold
O ideal.
So how do you set up? I have it so the flap is open all the time
Mr2 Rev1 tubby
my build thread
my build thread
Re: inlet manifold
EDIT- I might have it the wrong way round, just going to check- the valves may be open at lower rpm and closed at higher rpm.
Re: inlet manifold
There is a screw on the side to adjust how open they are.
I had mine off yesterday and adjusted it so they were as open as possible thinking its letting more air pass.
But now I'm thinking its wrong ha ha
Mr2 Rev1 tubby
my build thread
my build thread
Re: inlet manifold
Yeah- sorry I'm an idiot- they are normally open, and close at higher rpm to shorten the volume of the inlet manifold
I think you want to set the adjustment so that they fully close once you have a vacum applied to the actuator
Re: inlet manifold
Surely its needs to be closed? Because as it is it will never be sealed?
Mr2 Rev1 tubby
my build thread
my build thread
Re: inlet manifold
When it's open all it does is open the inlet tract to the sealed box above the butterfly valves, so the whole manifold is still sealed from atmosphere, but just has a higher volume.
Re: inlet manifold
When I say open I mean the flaps open
Mr2 Rev1 tubby
my build thread
my build thread
Re: inlet manifold
you need to put a vacuum tester on the vsv to close the butterflys and then adjust it for a proper seal.
why are you playing with it in the first place? what are you hoping to improve?
Re: inlet manifold
after head rebuild, my garage told me that half the butter flys in my have broken of the shaft.
alsoa
few aor leaks causing her to idle at 1600.
vac pipes have been replaced, but will buttler flys being duff hurt my MPG
what would this part be discribed as in an ebay search
