We built a 3sge powered Mk1, using a rev3 engine so 174bhp.
It didn't set my hair on fire if i'm honest, what you gain in power you lose in extra weight, so it sort of became a bit meh.
It's pretty much the same conversion to fit the 3s-gte instead which will blow your Mr2 world apart, it really will.
My advice is to go straight for the turbo motor, unless V6's are your thing, in which case the 1mz in a Mk1 makes the best combo of power/weight/handling and refinement i've experienced in a Mk1.
The only 3sge i'd consider in a Mk1 would be the Beams, but even then it will only give you stock Mk1 supercharger levels of performance.
You need to see a worthwhile gain for your money and hard work, hence the turbo route.
Hope that helps and if you still want to go 3sge i can give you all the help you need.
EDIT: to answer your question, fitting the 3s-fe would be a huge mistake, it would be slower than a stock 4a-ge Mk1.
