Could it be wiring, or just a sh1te stereo system in the car? It's just a cheapo dvd thingy
madbasshunter wrote:It could well be wiring Stevie depends how it was fitted and what fuses are used as I have seen glass fuses give intermittent faults and being an intermittent fault its harder to find, I would put a new good earth wire on and if that fails put a new permanent live wire straight to the battery with a fuse close to the battery(cut the wire and put a lucar connector on each end and push them on to a 10 amp blade fuse) any problems give me a shout.
