With a Grey top I would need to import from the USA and end up paying extreme money for the import tax and then the engine alone.
The red top is a good engine dont get me wrong, but theres more freedom with a Megasquirt ECU
(which I will run) when runnning Dual VVTi when it comes to ECU settings and pre programmed engine conditions, differences between the red top and black top being Dual VVTi, titanium valves and yes higher compression with 11.5:1
But does anyone have the dimensions of the blacktop??![](./images/smilies/spacer.gif)
Ive looked online but I cant find them
![Sad :(](./images/smilies/icon_sad.gif)
Now ive started emailing a few companies!
I'm begining to look at the 4G63T for my troubles with mounting, only difference being a mounting plate between the gearbox and block will need to be fabricated.
Its interesting to here about the intake manifold seems like another issue with what seemed to me as a failry straight forward fitment and hense why no one has done this before! The dimensions would be a usefull, again tho it looks like a whole new engine and gearbox
"repositioning", which would push me more towards the 4G63T as the amount of effort and welding is probably going to be the same however with a bit more cost.
The 4G63T comes with a MIVEC system and a turbo!
