i think my knock sensor has gone i keep getting error code 52, will a Rev2 N/A knock sensor fit a Rev2 Turbo?
I have used the search but couldnt find anything that was helpfull
Many thanks
Adam
Mike wrote:I've blown another one today(4 in 6 years!) I've no idea if an NA sensor will do the job.
Personally I'd like to know if there's a more robust alternative to the Toyota item.
Why couldn't they make a sensor that puts the car into limp mode but doesn't bloody disintegrate in the process.
They ain't cheap
Steve-O 2007 wrote:Mike wrote:I've blown another one today(4 in 6 years!) I've no idea if an NA sensor will do the job.
They ain't cheap
you must have a big problem somewhere in your setup then to keep blowing them.
You can get a more"robust" one called a GM Knock Sensor but its suposed to listen to different frequencies so might not look after the engine as good
at least a knock sensor is cheaper than a rebuild![]()
Are you Torquing it upto the right torque setting when you fit it?
