The brakes on my MK1 N/A lock up fairly easily.
My mechanical knowledge
Tellso wrote:Hi Guys,
The brakes on my MK1 N/A lock up fairly easily.![]()
would putting a set of ST202 or ST185 brakes on there help? Im not sure how it all works and would think that would give me more stopping power therefore be even easier to lock up?
Lauren wrote:Tellso wrote:Hi Guys,
That would make it worse.
Bender Unit wrote:You have 1 of the following:
1) Really good brake pads
2) Really rubbish tyres
3) A heavy foot
Unless you have swapped the brake pads for decent track compound, or your approach to braking is to stamp the pedal through the firewall- I would put my money on crap
/ worn tyres.
PW@Woodsport wrote:
Um no it really doesn't work like that Lauren, we have first hand experience of this as well..
think about it, a larger volume of piston but the same MC supplying them, so less lock up but overall better brakes.
Celica brakes vastly improve a Mk1![]()
PW@Woodsport wrote:.
Hmm I tried feamy with Willwood brakes on the front and it seemed to lock up way too easily on track.It really seemed to mess the balance up.
Actually though stock brakes are absolutely fine and up to the job for any NA or SC as long as they are in perfect working order.Brake bias is still too much to the front though as standard.
