Hi,
My rev 3 NA failed its MOT today allegedly due to the lambda sensor. Can anybody confirm that the rev 3 sensor is the same one as in the rev3 turbos?
If it is I plan to swap them over from my turbo to see if it does fix it before I go out & buy a new one.
[Mk2] [NA] lambda sensor
Re: [Mk2] [NA] lambda sensor
have a look at this ^^
I was 'close' to failing apparently due to lambda so let me know how you get on as I imagine it will be my turn in a few months.
Toyota part number = 89465-29825 for Rev3 N/A I think
double check using your chassis reference at http://www.toyodiy.com/
