[Mk2] [NA] How To Remove Alternator?
Goldy
Post by Goldy »
Hi,
I've tried every concievable way to remove the pivot bolt from the alternator to but its siezed solid. Can you remove the entire bracket and alternator from the engine in situ?
Thanks in advance,
Si
Ste2
Re: [Mk2] [NA] How To Remove Alternator?
Post by Ste2 »
From memory - you can only just get the alternator out of the top on its own.
This is a real a pig of a job if its seized up- I am also sure that my pivot bolt had some thread lock or similar on it.
Have you tried leavering the alternator with a breakers bar (or similar?) - you can often get some purchase off the boot wall. This might just help loosen it off a little (and any stray thread lock).
Other than that - the usual - WD40, torque, heat
daveslater3110
Post by daveslater3110 »
You cant get the bracket off, the driveshaft is in the way of the last bolt!easiest way is to get the alternator off and then the exhaust and bring it out that. Thats the way me and my mate did it. We couldn't get it out the top.
Dave
Ste2
Post by Ste2 »
you Should be OK getting the alternator out of the top on an N/A - turbo - I think I read somewhere that it is not possible
Driftlimits Performance
IMOC Affiliated Company
driveshaft only in the way for the turbos
jasongtr
Post by jasongtr »
unless you exhaust bolts llok like they will come off (not the rusty sticks that some have) then i wouldnt touch it
Goldy
Post by Goldy »
Skywalker wrote:driveshaft only in the way for the turbos
It's an N/A, does that mean I can remove the entire alternator bracket assembly without taking the alternator off the bracket? If so where are the bolts?
I've unbolted the suspension to get more access on the drivers side.
dazzz
Post by dazzz »
If you're really stuck bud. I'm not busy on Saturday so gimme a shout and i'll lend a hand.
Goldy
Post by Goldy »
Going to have another go with the impact driver and bolt grips tomorrow.... we shall see what happens :pray:
Goldy
Post by Goldy »
I've managed to move the alternator slight hitting it with a hammer and my breaker bar, enough so that I have now removed the belt.
I've tried a shedload of heat and the 14mm Bolt Grips and the 13mm bolt grips, neither of these can get enough purchase to shift the damn thing.
I'm giving up at this point, unless anyone has any better suggestions that don't involve welding nuts on.
I would like to remove the whole bracket but I'm not sure that this is possible with the alternator in situ. :pray: :pray:
The Offending bolt :
The clearance I have to work with :( :( Image
PsyKen
Premium Member
Post by PsyKen »
Maybe you will have to source a new bolt and grind it off :?:
I am sure that you cannot remove the alternator with the bracket still attached. When I did mine, the bracket came out the bottom, the aternator out the top.
Good luck.
Goldy
Post by Goldy »
My question is, can you remove the bracket with the alternator still attached? I'm yet to get a definative answer!
Lewis Jay
Post by Lewis Jay »
There are bolts that hold the alt. bracket on that cant be accessed without removing the alt.
Think your only option if you cant get that bolt out is to either cut the alternator and/or alt. bracket so you can get the alt. off then the bracket out.
Lewis.
PsyKen
Premium Member
Post by PsyKen »
Goldy wrote:My question is, can you remove the bracket with the alternator still attached? I'm yet to get a definative answer!
With my removal on my UK rev 3. No.
Goldy
Post by Goldy »
In the end, lewis got it freed off using Irwin bolt grips, highly recommended :thumleft: (both of them)
