I have been having endless problems with the car over-fuelling so bad on cold starts that the plugs turn instantly black and the car will barely run until it gets some heat in it and the plugs are cleaned off.
Maps and AFRs have been checked time and time again with no sign of fault and fuel pressure etc is good.
The longer i leave the car sit without starting, the worse it is!
I have also been losing about 1/8 of a litre of oil every time i go out for a whole day having fun in it
,giving it some good WOT pulls etc, however there is no blue smoke from the exhaust when the engine is warm.
-there is some when its ticking over cold after a few days no start.
Valve seal symptoms.
I have been putting my thoughts toward having bad valve stem seals or even stem guides, this therefore allowing oil to drain down and foul the plugs, preventing them from firing.
This combined with 1200cc injectors flooding the bores with fuel could explain why i am getting the all cold start problems and a lot of overfuelling soot on the plugs when it does decide to fire??
However.
Today i took off the head.
i cannot see any major sign of oil running down the valve stems, perhaps a light coating on the intake side? For my theory of oil fouling the plugs and preventing them from firing to work, the oil would have needed to come from the exhaust valves due to the angle the engine sits at, but these valve stems are dry.
Inspection of the pistons
/ bores shows no sign of any damage and carbon build up is minimal.
However, i did notice quite a bit of movement in all 4 of the pistons and im not sure if its excessive?
Here is a clip, sorry its not the best of recordings it was hard doing it on my own.
I did not have a tool to measure the amount of movement but i would say it must be about 1mm of play in all horizontal directions.
The block is a 3s with 5s crank, eagle rods
& 86.5mm omega forged stroker pistons w/ceramic skirts.
The engine has done about 3,500 miles and run 420 fly-bhp.
Can anyone advise?
thanks.
