mid_mounted_monster wrote:is there supposed to be fluid in the gaitors?
No, they're just there to keep the road dirt out of the inner joints.
mid_mounted_monster wrote:or is the rack seals gone?
It certainly sounds like it. Best bet would be to get the gaitors off or at least undo the clip/cable tie securing them to the rack and pull them to the side and have a look while someone operates the steering (with the pump running, obviously).
ahh, would this have affected the rack? as i have noticed for quite some time that my steering was very vague and used to wonder around and had a lot of play but all componetns (bushes,tophats,track rods inn+out,etc) have all been replaced, also gets quite stiff sometimes too,
thanks for the help so far guys much appreciated,
