Standard size for Crank to Con Rod bearings/shells
PlasticMonster
Post by PlasticMonster »
Hi, was hoping someone would know this off the top of their head...
I'm using a standard crank with Eagle rods and need to connect them together :)
Got the crank to block ones but cant find the size of these...Fensport were not exactly ..um interested.. lol
Thanks in advance.
Quigonjay
Re: Standard size for Crank to Con Rod bearings/shells
Post by Quigonjay »
why do you need to know the size?
if it is a standard crank there are specific bearings for the job without having to know the size
JJ
Post by JJ »
If it's a stock crank that hasn't been machined before, then all you need is a stock set of shells - ACL duraglide / Clevitte 77 !
PlasticMonster
Strange then that Fensport asked me for a size 1, 2 or 3???
Ill just have to call them up again!
ashley
Post by ashley »
Standard toyota bearings come in 3 sizes, the size you would need would be determined by the number stamped on the rod / main caps, and figures stamped on the block and crank shaft.
Have a look at the BGB: pages EM147 and EM149
http://www.mr2-tech.com/bgb/mechanical/ ... anical.htm
In your case you have after market rods, and so no reference for which size standard big end bearings you need. In the main it seems that the standard size ACL bearings will usually fit, but you will need to at least use plastiguage to check the clearance before you run the engine. If you are outside the tolerances described I think ACL will do you under / over size shells to compensate.
HTH :thumleft:
PlasticMonster
Ashman, really helpful reply thankyou. Ill pass this onto my engine guy.
Quigonjay
Post by Quigonjay »
ah, you didnt say standard ones
one would assume you meant aftermarket with using eagle rods
EDIT:hang on, this doesnt make sense
at the moment it sounds like you are going to aquire a set of bearings using your old standard rods then use them with the eagle rods? :-k
JJ
Post by JJ »
Whilst agreeing with all the comments with respect to the variation in sizes refitting stock rods back on the crank, toyotas tolerance levels are very high, so the clearance is at a minimal ! So no issue restoring the bottom end to the original spec.
When fitting aftermarket rods like eagle, carillo etc Ive always used the "sets" available from acl / clevitte 77 which have worked without issue, there's also a cost saving with these over Toyota parts too !
ashley
Post by ashley »
Quigonjay wrote:ah, you didnt say standard ones
I took it to mean he's using Eagle rods and a standard crank, and so wouldn't know what size Toyota bearings to order if he was gonna use Toyota bearings. The advice to use ACl (or similar) would get round this problem as they generally only sell one size.
JJ wrote:Whilst agreeing with all the comments with respect to the variation in sizes refitting stock rods back on the crank, toyotas tolerance levels are very high, so the clearance is at a minimal ! So no issue restoring the bottom end to the original spec.
I absolutely agree- I was just trying to explain why he was asked which size bearings he wanted when he called to order em :thumleft:
I would also completely agree that it makes more sense to use after market bearings as well :thumleft:
Regardless- I would think it sensible as a basic check to plastiguage for tolerances when installing bearings?
JJ
Post by JJ »
Keep us all in check ashman ! :thumleft:
ashley
Post by ashley »
LOL :lol: :lol: :lol:
Not intended dude- just trying to help the fella, just built me first 3S engine and my head's brimming with info- it's difficult to fight the temptation to share :lol:
JJ
Post by JJ »
I remember 10 year ago when there were claims of specialist tools needed to sort these mr2 engines out ! I'd stripped the 4age and 3SGE before tackling the Mr2s, how hard can it be !!Halfords set, big hammer and a deep set 32mm socket for the hubs, and everything was in pieces !!
Just nuts and bolts ! :mrgreen:
