[Mk2] [Turbo] Standard clutch limitations?
tommundy
Premium Member
Post by tommundy »
Hi all,
My current clutch has started to slip at higher boost levels ( >.8 ) and I was just wondering whether I'd be okay to run a standard exedy clutch (unsure of what is currently in there) on my rev2 engined Mk1.5 with the following mods:
Boost @ 1 bar
CT26 Hybrid
ST205 Chargecooler
I don't take it on the drag strip and am not thinking about any future mods to increase the power. However, it is used as a fast road machine and driven quite hard.
Will an OEM clutch be okay? I've read they're capable of upto 300ft/lbs, which should more than cover my power levels.
Any feedback greatly appreciated.
Cheers,
Tom
Chris
Re: [Mk2] [Turbo] Standard clutch limitations?
Post by Chris »
Sholud be sound mate. I ran one at over 300bhp in my Rev 3 for ages. Dragged it and lot. :thumleft:
Steve Horrocks
Post by Steve Horrocks »
Chris, what clutch did you end up using in your car? Mine has finally given up now!
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
