According to the commander the max knock it has recorded is 30 which is low and not reason for the light to come on.
Any ideas what could be causing this? I assume fault codes can't be read off these ecu's?
black gts wrote:hi mate
if the check engine light flash quickly then that means knock.
if it flash's slow then it means you have reached your injector limit(maxed your injectors out).
this is how mine is set up by Ryan
