[Mk2] [Turbo] gauge fitting
mr2daj
Post by mr2daj »
hi i got some gauges today for free. bargain! just have some questions about fitting. they are fuel pressure, trans temp, oil temp. i just have some questions about fitting. fuel pressure is easy. but where do i put the trans temp and oil temp? there both 1/8th NPT Thread sensors. any ideas? :-k
mr2daj
Re: [Mk2] [Turbo] gauge fitting
Post by mr2daj »
anyone?
Richie86
Post by Richie86 »
The easiest way for the oil temp would be to by a sandwich plate which sits in-between the oil filter and block. However as much as i rate this way, it depends on where your oil filter is.
On My old Rev1 it was located under the manifold, despite me wiring it up carefully and wrapping it in protective tape it eventually melted due to the amount of heat. Which also lead to the question of the accuracy it would have been reading before hand anyway.
The second way is to 'plug' it into the sump.
