Mr2_NA wrote:Undo the two bolts that attach it to the hub
Take brake line out
Undo drop links
Undo four bolts in the frunk
Sit on your ass and kick it just above the hub.
Falls straight out in one complete unit.
I didn't even touch the top mounts.
Just the four bolts holding it to the strut top.
Is this an easier way? 6 bolts in total.
Falls straight out in one unit, including the top mounts.
the four bolts are part of the top mount.
You were changing the whole shock inc top mounts with new ones??
I'm just replacing the shock absorber and putting the old top mounts on.
Not sure what you're getting at tbh.
Yeah the whole 6 bolts thing sounds easy in theory but it's not really the case and actually doing it provides a whole host of other issues.
Doubt I'd have attempted it if I knew it was going to be this much of a pain.
(And out the window goes thoughts of even trying a clutch change
Good ideas again Jimmy
, I'll have another blast at knocking the top mounts off, I was hitting it pretty hard with no luck, don't want to brake the thing lol.
Just seems as if I'm missing something, It's hard to believe the spring is meant to just fly out after the top mount bolt is taken off(which I didn't even know existed at first lol, I thought people were reffering to the 4 bolts, it was only after I investiigated further I found it and a bu88er it was to get off; much easier done when the strut is still on the car, indeed)
The main problem with getting the hub bolts to align in the strut is because the space between the strut bolt sections is really tight, I was thinking of hammering them out a bit of possible(if all else fails)
.So assuming I do get the top mount and spring off, will it be possible to get them on the new shock without the spring compressor?
Also, do I take all the materials off the old shock and put them on the new one, there is like a worn rubbery section at the bottom of the old shock and another rubbery bit that was up at the top mount that can be moved up and down the shock.
Be much appreciated if someone can answer these questions so I can get back to it and get it sorted.
If I do complete it, I shall write a noobs guide including the obstacles that may be faced upon the way.
(Should do it for the ARB's too, they were a PITA)
Cheers guys and you're help is much appreciated.
