Gearbox ratios
dannyh
Gearbox ratios
Post by dannyh »
Hi All, i have used the search engine on here but i cant find anything that can help me with this question. Are the gearbox ratios in a rev 2 n/a the same as a rev 3 n/a? my car is a rev 3 and it's now at this second having a rev 2 gearbox fitted to it, please tell me that it's okay :oops: i know there's an issue with the electronic/mechanical speedo but thats not bothering me at the moment.
many thanks
Slarty
Re: Gearbox ratios
Post by Slarty »
I'm pretty sure they do have the same ratios, and the speedo drive won't be an issue as it was only rev1 cars that had a mechaincal speedo drive, rev2+ had electrical :thumleft:
dannyh
Re: Gearbox ratios
Post by dannyh »
brilliant, thats sold it for me :clap:
thanks for the fast response :)
cantfindausername
Re: Gearbox ratios
Post by cantfindausername »
If the casings are the same you're ok. I have a Rev2 turbo, and had to buy a rev3 box to get it to match. There are transition period between all the parts I believe as mine is a late Rev2. It also had the indents in the rear panel for the Rev3 reversing lights. :?
I think it was rev1 N/A which had a different ratio. It seemed Rev2 had the majority of changes made to it so you should be ok.
***RIP Car13 ***
*** Now in an Evo ***
dannyh
Re: Gearbox ratios
Post by dannyh »
great thanks again, i'll hopefully get the car tonight and see for myself :) if it is a rev 1 box, i'm guessing the ratios are going to be lower :/
